JJJet JJJet is offline
Default need help with reinstalling OSX - 11-21-2010, 07:49 PM
The update to 10.6.5 messed up my Hackintosh, so I'm going to redo it and start from scratch. I have the Snow Leopard Disk, but it is version 10.6.1.
What NBI do I use?
I am using the take out the mini hard drive and put it in an enclosed usb drive cover and go thru my Macbook way.
Thanks in advance.
Slothtyper Slothtyper is offline
Slothtyper's Avatar
Default 11-28-2010, 04:47 AM
This one
After installing the 10.6.5 update I would run it again before restarting. If on a Mini9 you will probably then have to run the hibernate terminal commands to fix sleep and will definitely have to run the mic fix if you want that.
On the 10V just run the "hibernate image too old" terminal commands to get rid of that message and you should be good to go.
Mini 9 | OS X 10.6.5 Via USB Mac on 64G RunCore | 2G Ram | Bios A05 | NBI 8.4 Special | Bluetooth | Legacy Off | 1.3MP
Mini 10V
| OS X 10.6.5 Via USB Mac on 160G HD | 2G Ram | Bios A06 | NBI 8.4 Special | Bluetooth | Legacy Off | 1.3MP
« mini 9 external monitor on, internal off | Update from OS 10.5.6 to 10.5.8 »
