Jason Jason is offline
Default Re: OS X vs XP Heat? - 01-14-2009, 12:32 AM
Thanks... I'll give it a try...
Default Re: OS X vs XP Heat? - 01-14-2009, 12:39 AM
Originally Posted by CyG
Jason, you need to run your computer longer to get any kind of useful info on duration. I usually get one or two hours more performance at 10% battery because of the inaccuracy of the estimate.
BIOS A04 is supposed to fix the estimation, because it properly reports the actual size of the battery.
overload overload is offline
Default Re: OS X vs XP Heat? - 03-08-2009, 03:42 AM
I have the same heat problem, but the heat from mine is pretty hot, enough to where its too much to touch. I can't remember, are you supposed to hear the fan...or did you with XP or Ubuntu? I only had the laptop 1 day before putting OSX on it. Im worried my fan isnt working at all right now because of how hot its getting. Thanks!
  (#14) Old
CyG CyG is offline
Default Re: OS X vs XP Heat? - 03-08-2009, 03:49 AM
There is no fan in the Dell Mini, which makes it hard to hear.
Dell Mini 9 | Mac OS X 10.6.6 | BIOS A04 | NBI '51 | 16 SSD | 2 GB RAM | BT
« How to install iLife 08 after installing iLife 09? | Back to OS X »
