Default Dell TV Tuner for Mini... will it work with os x? - 01-09-2009, 04:55 PM
I hope so. It's cheap($50), small(thumb size), and has an antenna built in.
Hopefully it's small enough to fit inside the mini connected to a hub or something.
http://www.engadget.com/2009/01/09/dell ... ni-family/
DanielN's Avatar
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-09-2009, 05:57 PM
Probably not. You would have to get Elgato's EyeTV and then also make sure the USB stick is also compatible.
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-09-2009, 06:06 PM
Even if you could mount it inside the Mini, which I doubt, what are planning to do about the antenna?
Dell Mini 9 | Mac OS X 10.6.1 | 2 GB RAM | 32 GB Runcore
BIOS A05 | USB Legacy Mode: OFF | Internal Bluetooth
somms's Avatar
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-09-2009, 06:26 PM
Think I'll stick with my Hauppauge USB tuner which also can decrypt ClearQAM, has a better antenna inlcuded and support for real external antenna as well...
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-09-2009, 07:24 PM
What about if we didn't care about trying to mount it inside. What if we used it as intended and just plugged it into a USB port. Any ideas on if it would work with OS X or does it require some Windows Mojo?
Former owner of... (sold through this site)
Dell Mini 9
Other Mods - 2Gb RAM, RunCore "64"Gb SSD, Dell Wireless 1505 b/g/n, Dell Bluetooth, US "Int'l" Keyboard
somms's Avatar
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-09-2009, 07:30 PM
http://www.hauppauge.com/site/products/ ... 50mac.html
Doubt it...MAC specific tuners generally cost 2x as much as their Windows counterparts...
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-09-2009, 08:55 PM
I am guessing the in built one on the 10" would probably suffer for OS X drivers too
Oh well, if I ended up with one could always go the multiboot method on that one too lol
Dell Mini 9. 2GB RAM. 64GB Runcore SSD. 32GB SDHC. Novatel 3G WWAN.
Hacked MacBook Air SuperDrive. Real HD LED.
Quad booting OS X, Ubuntu 8.1, XP Pro and Windows 7.
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-10-2009, 12:21 AM
If the 10" has the rumored GMA500, those are the drivers it'd be suffering without.. You get just about zero video support in OSX when you don't have graphics drivers loaded.
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-11-2009, 04:24 PM
EyeTV Hybrid works with the Mini9Mac.
Just tried it with v.3.0.4.
jeffburg's Avatar
Default Re: Dell TV Tuner for Mini... will it work with os x? - 01-13-2009, 02:07 AM
I was really considering buy the EyeTV Hybrid but I have a question that I can't seem to find a solid answer for.
Does the Hybrid "NEED" and external antenna attached to it? Or does that just improve its ability to receive TV signals?
I want to get it for watching ATSC HDTV and I don't really want to accommodate for ugly Rabbit Ears on my Desk
Thanks!
-Jeff
« Use one keyboard and one mouse for two systems? | Mac OS X on any PC via Virtual Machine »
