| Member Posts: 87 Join Date: Jan 2009 | Hi all I'm a longtime lurker and first time poster. I finally caved in and purchased a mini 9 with 16gb ssd. I would like to put Leopard on it and have a couple of questions. What is a good external dvd drive to purchase? I saw some posts where people mentioned some dvd drives wouldn't recognize the leopard dvd and would like to avoid this problem. I'm almost tempted to purchase a xbox360 external dvd player because of that one video floating around. I plan on using this guide http://www.mydellmini.com/forum/howt...32--t1106.html and was wondering if I should use 7.7 or 7.6 or if it mattered. Also, I saw some posts about static coming from the speakers and the SD card slot not working and was wondering if there was any advice about those issues. I would like to avoid them from the get-go. I also saw some posts about saving space by not installing printer drivers and language support but was wondering if I could install individual drivers for specific printers and specific languages later on. Thanks for any and all help. |
(#4)
(#5)
| Member Posts: 87 Join Date: Jan 2009 | Hi all I went with the LG drive and I am stuck at the point where it says "Using default boot device 9f" Does this part take a long time? I'm not sure what to do. |
(#6)
(#7)
| Senior Member Posts: 135 Join Date: Nov 2008 | I am by no means an expert, but I beleive the version shouldn't be an issue. However it needs to be a full retail version (can't be one that came with some macs). If it still does nothing, it could be an issue with the drive not working well with the mini. A number of people have reported having up power off/up the cd drive again to get it to pick up. Dell Mini 9 Other Mods - 2Gb RAM, RunCore "64"Gb SSD, Dell Wireless 1505 b/g/n, Dell Bluetooth, US "Int'l" Keyboard |
(#8)
(#9)
| Junior Member Posts: 2 Join Date: Jan 2009 | I tried to use a pioneer 106 .. no luck.. tried a samsung dvd burner.. same issue.. all my other drives are sata so no luck there.. pain in the ass! I thought the disk was bad but my mac mini booted it and recognized it so not sure what the deal is.. I think i'm going to go with the method of pre-installing it to runcore 32gb from my mac mini.. such a pain |
(#10)
| Member Posts: 87 Join Date: Jan 2009 | Ok I tried the other dvd drive mentioned (Sony DRX-840U) and it doesn't seem to be working. Anybody have any suggestions? Could it be the version number? And yes I did check to make sure its a retail DVD. Thanks. |
