Igor Igor is offline
Default operating system not found!!! argh! - 05-02-2010, 08:10 AM
after i messed up my dell with a snow leopard update i tried starting from fresh again. i got xp back on it and when i plug the 2 sticks in and turn the machine on its says:
"PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM.
Operating System not found"
any ideas?
ive re-created the 2 sticks again using different methods but still nothing
i have a HDD with a backup of my snow leopard using time machine. i just want to be up and running again like i was before
Default 05-06-2010, 10:19 PM
RedHot RedHot is offline
Default 05-10-2010, 02:39 AM
jamesbarnhill jamesbarnhill is offline
Default 05-10-2010, 04:12 AM
Make sure you have USB Legacy Enabled.
---------- Post added at 11:12 PM ---------- Previous post was at 11:09 PM ----------
Also set your device boot order up correctly in your bios. (F2>>'Boot' tab>>select USB Devices>>set your small USB drive as the first using f6>>save and exit)
Hope that helps.
« iLife | Curious about Dropbox; what's the point? »
