sensbombers sensbombers is offline
Default 1000ha question. Please Help. - 04-29-2010, 11:27 AM
I recently got a Asus 1000HA after I couldn't get a Dell Mini 10v.
Was going to do put OSX on using the external dvd drive method but am having troubles. I bought the Snow Leopard upgrade disc from Apple (got sent the updated 10.6.3 version, this may be the problem) and got on my way using NetBookCD.
All booted to netbookcd and it detected the OSX DVD but when I boot into the DVD I get this screen:
It says version mis-match between kernel and cpu.
You need to restart your computer.
This happens every time.
What am I doing wrong? Is this solvable?
Please help. Getting pretty stressed out.
meklort meklort is offline
meklort's Avatar
Default 04-29-2010, 02:12 PM
An updated version of NetbookCD is needed for you to use the 10.6.3 disk.
If you are running Linux or Mac, (and have an 8gb + usb drive, flash or harddrive) you can create bootable disk using the 0.8.4 RC1 file.
For Mac, just follow the usual steps. If you have linux, I can run you through the procedure (but you'll have to make sure your install has all of the commands required).
My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a invite? message me.
ppafford ppafford is offline
ppafford's Avatar
Default 05-05-2010, 05:50 PM
Nice!!! Didn't know you're adding Linux Support for NBM/NBI, Thanks!
Mini 10v | N270 | OSX 10.6.2 | NBI 0.8.3 | 2GB RAM | 160GB | BIOS A05|
Mini 10v | N280 | OSX 10.6.2 | NBI 0.8.3 | 1GB RAM | 160GB | BIOS A05|
Dell Mini 10v OSX FAQ
10.6.3, netbookcd, osx
« Mac os 10.5.8 versus 10.6.3 | Meklort website down? »
