donbarger donbarger is offline
Unhappy Battery Toast - after 1 month of no use - 04-08-2010, 02:45 PM
Has anyone had their battery die after about a month of no use? When I turn it on it says that the system can't identify the battery and will not charge it. I have left it charging for 12 hours. I have removed the battery to try to "reset" it.
After about 30 seconds of use (plugged in) the system just turns off as if I pulled it out of the wall or something. Stinks because there really is no way to even reset it to windows to try to troubleshoot.
Any ideas?
brshoemak brshoemak is offline
Default 04-25-2010, 02:17 PM
I had the exact same issue with a refurbished Mini 10v. When I tried to plug in the AC adapter, the LED that would normally glow white (indicating charging) would flash amber instead and give me the error message you listed.
I had to contact Dell and thankfully it was still under the warranty period so they sent me a new battery. I have had the new battery in for months and no further issues have come up. A new battery is probably the solution.
battery, hackintosh, mini10v
« How do i save sl to a flash drive without a mac | I dont have a mac to use, or 8gb flash but.. »
