Ok so i set up my xp virtual machine fine with suns program. but when i am in it, all i can get is 640x480 4 bit color? i feel that there is a driver i am missing but im kind of lost.
I ran the guest additions and everything went smooth, but after a restart, i lost all color and screen resolution.
before the guest additions everything was fine (resolution wise)
anyone run into this and fix it?
thanks
doug
---------- Post added at 09:58 AM ---------- Previous post was at 09:30 AM ----------
oops nevermind i figured it out. but i do have another question for anyone running virtualization.
what have you found to be the optimal settings?
