Trilokavijaya Trilokavijaya is offline
Default audio recording apps on a dell mini; Logic Pro 8 & audacity - 02-16-2010, 02:38 AM
Hello out there in "Mydellminiland," could anyone please help me achieve a "what you hear" style of audio recording? Recording sound samples from the apps, mics, usb midi hardware, etc...
I'm transferring the studio setup onto the dellmini10/osx for on the go audio tinkering/editing. The main rig was a PC, soundforge, ableton, sonar, and fruity-loops. (yeah, i still produce with loops)
In logic 8, under preferences->audio->devices->core audio-> the device bubble says..."built-in input"...
Are there ways to set it up to record the audio of other apps? such as quicktime, itunes, vlc, etc?
I'm trying to do the same thing is audacity, it says "default input source"...
OSX 10.5.8|Dell Mini 10v|2GB RAM|160GB HD|A05 Bios|Dell EFI method (Anguish-Youtube Ver.) |TrippleBootWin7-OSX-Ubuntu
jmacie jmacie is offline
Default Check Soundflower - 02-16-2010, 03:26 AM
Google soundflower. It's like an analog loop back. I don't and haven't used, but have checked it out.
chrispi79 chrispi79 is offline
Default 02-16-2010, 01:22 PM
I work with Logic Studio on a real Mac, i dont think, that the mini is fast enough to do that.
mini10v | 10.6.3 | 2GB RAM | 64GB SSDNOW V-Series | NBI 0.8.4RC1 | A06 | BT:no | WAKEn LEGACYff
TheAAPLFreak TheAAPLFreak is offline
TheAAPLFreak's Avatar
Default 02-16-2010, 04:21 PM
I'm pretty sure that the Dell Mini can handle Soundflower. As someone said before, it's an audio loopback which you can use to record system audio. OS X supports it as an input option right out of the box, but you need to have Soundflower running.
Macbook (April 2008) | Intel Core 2 Duo 2.4 GHz | 4 GB RAM | 250 GB 5400rpm HD | OS X 10.7.3
Dell Mini 10v (August 2009) | Intel Atom N270 1.6 GHz | 2 GB RAM | 120 GB 5400rpm HD | OS X 10.6.8 (borked) / Windows 8 Consumer Preview
GA-X58-USB3 (January 2011) | Intel i7-950 3.2 GHz (OC'd) | 6 GB RAM | 1 TB 7200rpm HD / 120 GB 5400rpm HD | Windows 7 Ultimate / Windows 8 Consumer Preview / OS X 10.7.2
« Best Dell Desktop to install OSX | Dell 5530 OS X set up »
