Bgleonard Bgleonard is offline
Default Please I really need help, please help me. - 02-04-2010, 11:51 PM
I was trying to use my 150gb external HD as a boot disc for mac os x snow with no guides or help with installing to an external hard drive using transmac i tried to do it on my own.
Heres the steps i did.
- right clicked on external HD and formated to HFS+
- then i clicked on format with Disk Image then clicked on my Mac OS X Snow file and let it do its loading.
I then thought i had it so i restarted my computer and booted with that, only to find it saying insert something i can boot it with.
So i restarted and got back in windows 7 only to find that since i formatted the HD in an attempt to put on the OS, it no longer shows up in windows so i cant fix it.
So then i found my 8gb flash drive, only to find out its actually only 7.4gb so does anyone know a way to get the full 8 gbs on it, thanks.
Retired Mini user
WolfKeeper's Avatar
Default 02-05-2010, 12:55 AM
There is no way to get all 8.0GB, because of the math involved.
8GB really means 7.4GB using the .93 rule.
Getting an iPad
« ExoPC Slate | The problem using a Mini Hackintosh in public is... »
