Edwand Edwand is offline
Default Installation problems on both Method 1 & 2: need advice - 01-11-2010, 05:05 PM
Anxious to get computer working !
Tried two different methods, and have different issues with each
Computer : New 10v with A06 firmware
USB: 1 gb & 16 gb, both reformated per method used
Software: retail version of Snow Leopard 10.6
Both mechdrew methods
Method 1
Netbookmaker USB on Mac Error: kernal panic(cpu 0 caller 0x1b33f459 "Unsupported CPU: family=0x6
Tried redoing the complete process twice with no luck, always same result
Method 2
NetbookInstaller Two USB on Windows
1st try: appeared like it was working, got thru initial Mac DVD selection process before crash
Succeeding trys: get error 'Can't find mach_kernel' quickly before even starts loading.
Also attempted to redo complete process including reformatting USBs with no luck
What should I try next ?
« EFI Simulation Problems - Please help... | A big thanks »
