tjolley tjolley is offline
Default Shutdown issue. - 12-19-2008, 09:33 PM
I am having a shutdown issue with my Mini9.
I read this in another post:
It's the sound driver.
Read the part about
[SOLVED] Kernel panics on shutdown (and subsequent hanging on first reboot).
It'll direct you to the MSI Wind forum. You have to remove 2 old driver files and replace with new updated driver files. This does fix the kernel panic. Good luck."
But it seems that the link to the MSI Wind forum is no longer there, and I cannot locate on that forum.
Does anyone know which drivers need to be removed, and where the new drivers can be obtained?
Default Re: Shutdown issue. - 12-19-2008, 09:44 PM
Which install method are you using?
« Is runcore the only way to get sleep to work? | Disk Utility hangs when attempting GUID partition »
