murfy++ murfy++ is offline
Default no battery? - 12-17-2009, 08:26 PM
i have a dellmini9 with mac OSX leopard 10.5.8 installed. I haven't turned it on in several months. today i turn it on and it will only run of AC and it won't charge the battery. whenever i unplug the adapter the machine immediately turns off. anyone experience anything similar? / know how to fix it?
also sorry if this is in the wrong place. i don't know if this is an issue with OSX or hardware.
edit: so i think the battery might be charging? in the menu bar it says 1% and says 10:00 until full :/
SkyWriter SkyWriter is offline
SkyWriter's Avatar
Default 12-17-2009, 09:45 PM
leave it charging overnight.
Problems with external displays or projectors in OS X? Try MirrorDisplays2!
Got Static?
ppafford ppafford is offline
ppafford's Avatar
Default 12-18-2009, 01:21 PM
Please post with an update, would like to know the outcome of this. Thanks
Mini 10v | N270 | OSX 10.6.2 | NBI 0.8.3 | 2GB RAM | 160GB | BIOS A05|
Mini 10v | N280 | OSX 10.6.2 | NBI 0.8.3 | 1GB RAM | 160GB | BIOS A05|
Dell Mini 10v OSX FAQ
Default 12-18-2009, 01:52 PM
I've read that Li-ion batteries can die permanently if absolutely, completely discharged (beyond the level that the managing electronics allows). I don't know if that's the case here.
Default 12-18-2009, 04:15 PM
ok turned it off and let it charge for a few hours and now everything is back to normal ... i guess i just let the battery completely die on me. never done that before.
thanks for the help
« Accidently installed NBI on my MACBOOK | Questions on how to upgrade from 10.5.6 to Snow Leopard »
