| Member Posts: 66 Join Date: Aug 2009 Location: New York! | On my mini 10v it worked, that's how i installed osx Thank God for Time Machine Dell Mini 10V, N280, 160GB, Snow Leopard 10.6.4 -Totally screwed... |
| Guru Posts: 1,353 Join Date: Feb 2009 Location: Colorado, USA | If you really want to, you can create a helper partition on the internal drive that has the kernel and /extra folder (for the extension cache). You'll need to edit the boot plist so that the kernel knows to boot off of the sdhc card (easiest way is with a root=uuid) The steps to do this are basically 1) Install the os to the sd card as usual (making sure netbook install is run on it) 2) Create a helper partition on the internal drive (or a usb drive) and install chameleon to it (you can use NBI to do that) 3) Copy the /Extra folder on the sd card to the internal helper partition and finaly, setup the boot plist on the internal drive to point to the sd card. This does take a few extra steps verses the normal install (say 5 to 10), but it's doable. The sd driver fro mac os x isn't very good, so you will have performance issues as well as a higher chance for data loss. The same thing goes for booting linux from the sd card. You'll need a helper (boot) partition on the internal drive with the kernel and driver (and any ramdisks you might use). Dell Mini 10v | Mac OS X 10.6.5 | 1 GB RAM | 160 GB HDD | BIOS A06 My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a Lockerz.com invite? message me. |
