jdcnosse's Avatar
Send a message via AIM to jdcnosse Send a message via MSN to jdcnosse Send a message via Yahoo to jdcnosse
Default OS X and Bluetooth audio - 11-09-2009, 05:40 AM
I was just wondering if anyone has had any experience with Bluetooth headphones or speakers and OS X. If so, how's the quality? I'm thinking of getting a pair only because I don't want to have the cord with my Mini. Also, does the audio work when you've got something else using the Bluetooth connection as well?
Custom-built | AMD Athlon 64 X2 4600 | 2GB RAM | 1.4TB total HDD space | ATI Radeon HD 4650 | Windows 7 Pro 64-bit
SkyWriter's Avatar
Default 11-09-2009, 01:18 PM
the audio quality of bt is never very good, but yes it does work with a bt mouse active as well.
« Mini 10v SL and iPod Help | Partition: Free space less than available space »
