(#11)
(#12)
| Junior Member Posts: 10 Join Date: Feb 2010 | Quote:
![]() Hope it works for you. | |
(#13)
| Junior Member Posts: 3 Join Date: Mar 2010 | Quote:
im now trying a different HD... will update progress cheers | |
(#14)
| Junior Member Posts: 2 Join Date: Mar 2010 | The problem that I am having is that Disk Utility won't let me drag the "MAC OS X Install DVD" to the Source box. In fact, my "MAC OS X Install DVD" is grayed out. Even though above it is not "PIONEER DVD-RW DVRTS08". I am running Snow Leopard on my Mac Mini. I have the retail DVD of Snow Leopard in my drive. I have a 8GB USB Flash drive plugged in. I partitioned the USB drive (1 partition, Mac OS Extended, Master Boot Record, yada yada). But it's when I go to the Restore tab and try to drag my Snow Leopard Install DVD over to the Source box, it won't let me. Dragging the USB Drive "OSXDVD" to the Destination is no problem. Does anyone know how to get around this? Is this because I am running Snow Leopard on the computer instead of Leopard? Thanks for any help. |
(#15)
| Junior Member Posts: 2 Join Date: Jul 2010 | Quote:
Finally, I tried a different external USB DVD player and it worked perfectly the first time. | |
(#16)
| Tags |
| allocate, memory, restore |
« Help plz: disk erase failed with error posix reports cannot allocate memory"
**OFFICIAL** Mac OS X 10.6.4 Update Thread »
