Type11 Type11 is offline
Default Drop script to copy kext to EFI Partition - 12-06-2008, 03:22 PM
If you are using the Type11/Boot132 method this might help you. I wrote a little drop script that will copy kext files you drop on it to the EFI partition, update the cache on EFI partition and unmount the EFI partition. Note it only works on the current running disk. Meaning when you run it, it will copy to EFI partition on disk you are booted from. You can drop multiple kexts on it. Enjoy and let me know how it works for you.
« no mac, no external cd/hd now what? | Cursor ghosting »
