faithefin faithefin is offline
Default USB worked... Now does not - 12-04-2008, 05:49 PM
I have a DellMini 9 with OS X 10.5.5 successfully installed. Works great!! Love it.
Originally all my USB ports worked. I could put in a memory stick and transfer files.
Now, for no apparent reason, the memory stick doesn't show up on the desktop. It does show up in System Profiler.
Any ideas?
jeffburg jeffburg is offline
jeffburg's Avatar
Default Re: USB worked... Now does not - 12-04-2008, 06:53 PM
Open Disk Utility. Its in your Utilities folder in the Applications Folder. The Drive may need to be repaired.
« Driver installation | How-To's? »
