minimac1974 minimac1974 is offline
Default Restoring PowerPC applications using Time Machine - 10-02-2009, 10:46 AM
I have installed Snow Leopard on my Mini 9 (2 GB RAM, 32 GB stock HD, no bluetooth) after some minor difficulty. Also, I used to own an Emac with Leopard loaded and a backup Macally drive enclosure with which I made Time Machine backups of my applications.
In the past, when I had Leopard installed on the Mini 9, I have tried a Time Machine restore of the applications with the result of having my Leopard install being hosed.
Does anyone know of a tip that can get me my old applications loaded onto my Mini 9? Thank you to everyone in advance!
grassle grassle is offline
Default 10-02-2009, 11:37 AM
You could manually go to the latest completed backup on the TM disk, the path is <your-time-machine-volume>/Backups.backupdb/<name-of-your-mac>/yyyy-mm-dd-hhmmss/ .
Find the Applications folder and drag the apps to the mini Applications folder. Do the same with the desired contents of Application Support, Preferences, etc in /Library and in /Users/<your-user>/Library.
Don't forget that running PPC apps on an Intel Mac requires Rosetta to be installed.
« How to tell if NBI completed OK | Glossary for Non Mac types »
