| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | These are the steps you would need to take :
Detailed instructions provided from the following guide. In no way, shape, or form do I claim these instructions as my own work. Props to mechdrew. NetbookInstaller 1: USB Installation via Mac | Guides | OS X | mechdrew Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
(#4)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | No problem glad you feel "at home" and welcomed at MyDellMiniWe try to be as helpful as possible. I guarantee you will enjoy your Mini and that the installation will not be as hard as it seems. After you do it the first time you will wonder why you ever thought it was so difficult. Thanks to meklort for the amazing work on NBI/NBM because the installation would not be nearly as easy without those wonderful tools! ![]() Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
(#5)
(#6)
| Member Posts: 92 Join Date: Sep 2009 | bmcclure937's post points to both versions of NetbookBootmaker (0.82 final and 0.83 RC1 testing) If you use 0.82 stick with his tutorial. Ignore the rest of my post. ![]() If you don't mind some extra work and wanna use 0.83RC1 (for example because of a better Touchpad driver) here is some exta info: In 0.83RC1 there is a Bug that the NetbookInstaller won't be installed. But because of the new Touchpad driver I think choosing 0.83 RC1 is worth it. Simply do this instead of Step 6 fom bmcclure937's tutorial: Quote:
Some additional tips: Use method 1 from here: http://www.mydellmini.com/forum/os-x...sleep-10v.html To get Audio after Sleep in Snow Leopard with a 10v. Takes about 15-20 seconds after wakeup, then it will be reactivated. Also the Hibernate isn't turned off correctly. So you loose about 1GB diskspace See my post here for how to turn it off: http://www.mydellmini.com/forum/104703-post217.html | |
(#7)
| Member Posts: 32 Join Date: Sep 2009 | Thanks Thyraz! I see what you mean...I'm not afraid about extrawork, I'd like to try out things in order to get the best combination DellMini/SL. I'll study a bit what you've posted and comeout with some questions, surely! ![]() ---------- Post added at 04:26 PM ---------- Previous post was at 04:15 PM ---------- Questions about the first post of bmcclure937: - Point 2 has still to be done on the iMac, right? - About the point 4...it means that I have to turn on the DellMini after having insert the USB pen? |
(#8)
| Member Posts: 92 Join Date: Sep 2009 | Yes, Point 2 is still on the Mac, and Point 4 is booting the Mini from the USB-Device u prepared. Insert in the Mini, ensure that USB-Legacy is activated in the Bios and press F12 after power-on. This should bring up a list of boot-devices. Select USB and press Enter. |
(#9)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | I would still highly recommend (for a beginner) using the method I outlined. This ensures they are not using a Release Candidate (especially RC1) of NetbookBootMaker. Obviously, Release Candiates are in testing and still contain bugs. They do usher in improvements, but the overall solution may be rough around the edges. For the simplest install method, I would highly recommend .8.2a [final]. Once NetbookInstaller .8.3 has been polished up a little bit more then you could upgrade (which is as easy as downloading the new NetbookInstaller and running the application) ![]() .8.3RC2 should be out by the beginning of next week and then testing will continue on .8.3... For now, the easiest method to use is the one I detailed ![]() Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
(#10)
| Member Posts: 32 Join Date: Sep 2009 | Quote:
![]() Quote:
![]() ---------- Post added at 05:06 PM ---------- Previous post was at 04:56 PM ---------- Other questions: concerning the wireless and the BT. Does make any difference having the Dell 1510 (802.11n) instead of the Dell 1397 (802.11 b/g)? And: does the BT work? ![]() | ||
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/13303-sl-mini-10v-im-bit-lost-sorry.html | ||||
| matan.lurey's Bookmarks on Delicious | This thread | Refback | 09-29-2009 12:38 AM | |
...and thanks in advance!
