Crisu Crisu is offline
Default No sound for short audio-jingles - 09-25-2009, 11:02 AM
There is a problem with sound and short audio-jingles.
After booting the system you won't hear short audio-jingles like erasing the recycle bin, erasing a file, and so on.
You can fix this problem only temporary for 2-3minutes if you press the key F7 (audio on/off).
You have to press f7 until the "click-sound" appears for turning sound on/off.
Now you can delete a file, erase you recycle bin or even you can hear a short sound if you are receiving mail.
But after 2-3 minutes or so, this fix doesn't work! You are at the same point, and audio for short jingles won't appear.
It seems, that OSX needs a longer time to initialize audio... For instance, you hear sound for long audio (youtube-videos, mp3-files and so on)
Has anyone this problem, too?
OSX 10.6.1, NBI 0.8.3 RC1
Mini10v, BiosA04, USB legacy: off, Usb wake: off, Bluetooth: on
« No Audio After Sleep on 10v | Does the internal mic work on Mini 9 and OSX? »
