RazorsEdge RazorsEdge is offline
Default MIni 9 os x worked for a couple weeks then... - 09-24-2009, 05:29 AM
I Installed os 10.5.8 directly onto a runcore 32gb sdd. Everything worked fine for two weeks except a sleep problem. Then I turn it on tonight, and as it boots, I get the dell logo, but it seems bigger and is lower on the screen. Then the apple logo shows up, but instead of being stretched horozontally as usual, it is scaled correctly, but it is lower on the screen. Then momentarily, I get the blue screen, then it goes to dark blue/black. It stays this way. The computer seems to be on (I can hit some keys and get some beeps etc, but Can't see anything.
I took the Runcore out and hooked it up to my mac, and everything seemed to work normally. Booted it up fine. Put it back into the mini 9 and got the same problems. Any ideas?
I tried my old 4gb sdd that came with it and Ubuntu booted fine.
« White Screen @ Boot Up | Ok Guys »
