Mantulen Mantulen is offline
Exclamation Vertical vs Horizontal touchpad speed (driver issue) - 09-17-2009, 01:27 AM
I am currently running 10.5.7 on my Dell Mini 9. The vertical speed is much faster than horizontal speed of the mouse movement (not scrolling) on the touch pad. I think this has something to do with the touch pad being rectangular vs traditional square size on older laptops. Since OSX sees the touchpad as a square shape the horizontal speed is slower because the actual touch pad is wider. You can easily check this by moving your finger in a circular motion and you will see the mouse moving in a vertical oval shape instead of following the circular path you are doing with your finger.
I am thinking to upgrade/clean install to 10.6.1.
1) Is the mouse pad issue fixed, or same problem?
2) Is there an alternate mouse driver that fixes the ratio of mouse speed?
meklort meklort is offline
meklort's Avatar
Default 09-17-2009, 03:02 AM
It's a bug in the driver included with 0.8.2. The v18 driver works fine, and the driver included in 0.8.3 (when it's released) has it fixed.
My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a invite? message me.
« MSN Messenger for Mac | Install OSX onto USB Drive? »
