Posts: n/a
Default Incorrect Hardware Info - 09-12-2009, 07:28 AM
Hello team,
I've just noticed in my System Profiler, hardware info is incorrect, I'm on a mini 9 with 10.6.1 and it says:
Hardware Overview:
Model Name: Mac
Model Identifier: Inspiron 910
Processor Speed: 1.6 GHz
Number Of Processors: 1
Total Number Of Cores: 1
L2 Cache: 512 KB
Memory: 2 GB
Bus Speed: 533 MHz
Boot ROM Version: MBA11.88Z.00BB.B00.0712201139
SMC Version (system): 1.13f3
Serial Number (system): HDMTWF1
Hardware UUID: 00000000-0000-1000-8000-000000000000
I don't think it was like this on Leopard, I actually remember it saying the correct Model Identified and also shows 2 cores... Is there a fix for this? Or did I run the wrong about info package?
scififan68 scififan68 is offline
Default 09-12-2009, 03:02 PM
Here's my smbios.plist so it shows you have you a have a MacbookAir1,1, just place in /Extra and reboot!
File Type: zip (979 Bytes, 44 views)
Dell Mini 10v: Obsidian Black, 1GB DDR2 533MHz Ram, 1.6GHz Intel Atom, 120GB FUJITSU HDD, 6-Cell, Mac OS X Snow Leopard 10.6.3 Build 10D573 booted with Chameleon 2 RC5 pre6, Dell Wireless 1397 flashed! (Everything working, now featuring sleep when closing lid!)
nervis67 nervis67 is offline
nervis67's Avatar
Default 09-13-2009, 05:21 PM
I did put smbios.plist in the extra folder and rebooted. it does show I have a MacbookAir1,1 but when I go to load certain plug-ins, it says they can not load onto a power pc? did I do it wrong or is there another step I missed?
Mini 10v | 1Gb RAM | 160 Gb HDD | OSX 10.6.6 | NetbookInstaller .8.4RC1 | BIOS A04 | USB Wake : OFF | USB Legacy : ON | No BlueTooth
« Hows the performance of 10.6 vs. 10.5.8 | Snow Leopard update 10.6.1 »
