Default Fix for USB Legacy Support stuck on Enable? - 09-11-2009, 04:40 PM
I've been searching... I saw to rerun the NBI with generating a new DSDT... Didn't work.
I'm on a Dell Mini 9 on A04. Any idears?
Vostro A90 | 64GB SSD | 2GB RAM | BIOS: Dell Mini 9 A05 | Mac OS 10.6.1 | 1505 802.11N Wifi | .3MP WebCam
Default 09-14-2009, 01:30 AM
I'm still stuck. Anyone?
meklort's Avatar
Default 09-14-2009, 03:01 AM
The only think I can think of is if you used an old version of NetbookInstaller.
If you did, try running the latest version, install Chameleon RC3, reboot and then try regenerating the dsdt.
If that doesn't work, try going to /Extra and deleting the dsdt manual, rebooting, and then regenerating it.
DMBryant's Avatar
Default 09-14-2009, 10:03 AM
I had this same problem, my BIOS settings kept getting reset every time I restarted. Re-running NetbookInstaller didn't seem to fix the problem. I then manually deleted the dsdt file (and in the process found another, older, version of dsdt in the root which I also deleted) rebooted, regenerated the dsdt, rebooted again and now everything works. BIOS settings are saved
Thanks for all your help and hard work Meklort!!!!
Mini 10v | 2GB RAM | 120GB HDD | 1510 N Wireless | BT 2.1 | OSX 10.6.4 | NBI 0.8.4RC1 | Bios A04 | 1010 Touchpad | Magic Mouse
meklort's Avatar
Default 09-14-2009, 01:21 PM
Ah, good point.
If you've used and old version of DellEFI any time, /dsdt.aml will exist and override the new default at /Extra. The /dsdt.am; file needs to be deleted (I'll have the next version do that).
lugesm's Avatar
Default 09-14-2009, 03:45 PM
Good catch. I searched my Mini9 and found two (2) copies of dsdt.aml . . . . one of them dated last May. I deleted the one dated May 09, and the system seems to still work well.
Thanks for the tip !
Dell Mini10v, 64GB RunCore Pro IV SATA SSD, 2GB Memory, A06 BIOS, 10.6.7, NBI 20100616212351, Bluetooth enabled (external dongle), USB Legacy disabled.
bmcclure937's Avatar
Default 09-14-2009, 04:30 PM
Last May would be May 2008, not 2009 but we all know what you mean...
lugesm's Avatar
Default 09-14-2009, 04:38 PM
Depends on your geographic location.
Default 09-15-2009, 01:03 AM
I found 2 dsdt.aml files, but one is in the Extra.bak folder. Can I delete the Extra.bak folder completely?
Default 09-24-2009, 04:34 PM
I am having this same problem.
It wasn't an issue until I ran NetbookInstaller .8.3RC1 on my Mini 9. After running that, my BIOS resets every time I restart. I have used finder to search for dsdt.aml files and found 2 of them. I deleted both and reran Netbookinstaller, same result. I also found a thread that uses terminal to delete the dsdt.aml file (I'm a Mac newb), I followed the instructions and same thing. It's starting to drive me crazy.
Anyone have any ideas?
« OSX Always Booting to External Monitor | Dropbox, moving folder to SD drive? »
