Default 09-11-2009, 08:20 AM
i just did your work around on my other mini. my mic is not working on mines. but if this work im going to reinstall SL and do it all again. but both my machine dont like to restart.
Default 09-11-2009, 08:25 AM
on the other mini with your method in post 8 works. but has static here and there. no bad. now how do i reverse it and go back to my old ways?
Default 09-11-2009, 08:27 AM
So ya both of my mic and audio is working, but only on my jack... I mean the speakers arent much, but it would be nice if it worked on both... I am pretty new on snow leopard...do you know if the jack always worked for audio after sleep...did I at least improve on something haha. VoodooHDA will give you audio on both, but it was distorted for me...I might try again just to see.
  (#14) Old
Default 09-11-2009, 08:28 AM
it works good enough to redo my machine again!! this is a great find thanks alot.
  (#15) Old
Default 09-11-2009, 08:29 AM
well i have audio on both. just mic isn't working. im going back to the old way for now. i wonder how i can do it without starting over?
  (#16) Old
Default 09-11-2009, 08:38 AM
Ya it's weird... Did you uninstall Voodoos system prefs plugin? Just right click and remove. repair permissions and restart and see what works after sleep
  (#17) Old
Default 09-11-2009, 09:15 AM
Hey voda check out my first post. I edited it to include the sleepwatcher method. I changed the scripts and it works better for me... try it out
  (#18) Old
Default 09-11-2009, 05:57 PM
for method 1 do you use terminal? can you break it down some more to edit those files? i want to try it but when i go to terminal and copy your command it didnt work.
sorry if im being a noob.
  (#19) Old
Default 09-11-2009, 06:26 PM
method 1 i use reymeida guide in step 7. but instead of pasting his commands i did yours with rc.wakeup and rc.sleep rebooted and still no sound after sleep. dont know if i did it right. im going to leave it like this for now til i hear back from you.
  (#20) Old
Default 09-12-2009, 12:37 AM
So make sure you do everything in reymedia's guide up until you edit those rc files. Make sure you load both files of sleepwatcher. One is the main file and the other is a startup loader to ensure you have it every time you boot.
Go to your terminal and type
sudo nano /etc/rc.sleep
remove the contents of the file ctrl+k will delete line by line...just hold it down
copy and paste my little rc.sleep script (3 lines).
Ctrl+x to quit.
Push Y to save
Do the exact same thing, but for rc.wakeup
Save it and then try it out. It takes about 10 seconds for audio to come back after sleep, but for me everything works. So try it out..
« Organising the Mac OSX Section | What Do You Call Your Mac? »
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/12700-two-methods-get-sound-after-sleep-10v.html
Posted By For Type Date
Post Installation Steps on My Snow Leopard Dell Mini 10v Hackintosh | Hackintosh Laptop This thread Refback 09-29-2009 03:24 PM
