Default unusual issue 10.5.8 and screensavers don't work? - 09-06-2009, 01:14 AM
my dad's mini9 with runcore 32GB, 2GB ram and OS/X 10.5.8 successfully installed via an imac using runcore method - applied netbookinstaller rc4 in safe mode and have sleep, trackpad and battery meter all working as they should.
however, all system screensavers except for two of them crap out or fail to load. i figure something must have gotten corrupted somewhere as two do actually work (computer name and flurry) - none of the others do however. I can access all the pref panes and all the config settings but if i try to test one or run one via hotcorner they don't work or they don't give the expected results.
these screensavers worked previously when the system was on 10.5.7 and DellEFI 1.1.
anyone have any ideas on how this might be fixed?
iv'e tried reinstalling the screensavername.saver file and replacing the existing but that doesn't seen to take.
Default 09-06-2009, 03:02 AM
I would check my Graphics/Displays in Hardware Profiler and check that Quartz Extreme and
QuartzGL are both shown as supported.
I tried my screensavers for the first time before posting this, and they all work perfectly. I did a fresh install to my mini 9 using the old DellMiniBoot123 disc, so I don't know if it is an install method issue, or if it is your hardware.
Functioning Hibernation
« mirroring command not there in Snow Leopard? | How to install the original XP Bootloader? »
