(#21)
| Junior Member Posts: 21 Join Date: Jun 2009 | I'm aware of how to get to single user mode. I was more interested in what command sequence you used to make the user account. this is what i was working from: How to: Add a user from the OS X command line, works with Leopard! - OS X Daily Following that I ran into problems with creating the home directory and upon reboot into the gui it wouldn't let me use the user i just created. |
(#22)
| Member Posts: 60 Join Date: Jul 2009 Location: Brawlmore, MD | Quote:
Edit: Actually I don't know where the cmnd key is located on a hackintosh, so I also need to know what's the equivalent cmnd + S. | |
(#23)
(#24)
| Member Posts: 57 Join Date: Nov 2008 | Sorry, I misunderstood you. I created my admin account by going through the usual steps after being presented with the startup video when starting up in single user mode. The same exact way you would go about setting up an admin account for the first time in Leopard. Quote:
(#25)
| Super Moderator Posts: 1,420 Join Date: Mar 2009 Location: United States | Quote:
The Alt button is Command (or Apple key)Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides | |
(#26)
(#27)
| Junior Member Posts: 17 Join Date: Aug 2009 | Quote:
As for getting sleep to work, I'm pretty sure you have to run the new "Kext Utility" after you install kexts with "Kext Helper" in Snow Leopard for them to work correctly. Mine is sleeping fine, although I haven't had time to figure out why it doesn't sleep when I close the lid, I'm still hitting sleep from the power button/Apple menu. It wakes up fine when I open the lid. Look for TeknoJunkie's Snow Leopard Files package on Insanelymac to get "Kext Utility" | |
(#28)
| Member Posts: 60 Join Date: Jul 2009 Location: Brawlmore, MD | Well my mini keeps hanging on the first time set up. It gets stuck right on the transfer info from another Mac. I tried re-installing with the same results. I tried running netbookbootinstall from the installation window (under utilities menu,) that didn't help. I guess I'll try the single user mode. I googled creating an admin account and came up with this: Gain Administrative Control of Mac OS X - MacShadows KB I hope that works. Well I've tried pressing alt-S at different times during start up. During the dell logo doesn't seem to be do anything. Won't work when it's counting down from 5 because that'll only send you to start up options. And at the apple gray screen it is too late. What am I missing? |
(#29)
| Member Posts: 60 Join Date: Jul 2009 Location: Brawlmore, MD | Ehh, I'm gonna try installing 10.5 and do an update from that. I've tried every other idea I had. Ehh I'm so stubborn. At this point I will accept nothing less than 10.6 on my mini. I probably won't go to sleep tonight. |
(#30)
(or Apple key)
