Default How to get vanilla audio working after sleep! - 08-09-2009, 06:26 PM
I have figured out how to get the internal speakers(lnxneo's drivers) working after sleep! I used the same sleepwatcher method once used with voodoo drivers and it worked!
Check step 6 of my guide here: Fool Proof No Hassle Mini 10v Install EVERYTHING WORKS!!
Feel free to use me as a referral on click there ᐯᐯᐯ
Default 08-09-2009, 08:14 PM
If you have 10v and VerbHelper installed correctly, you should not need step 6. VerbHelper should take care of internal speaker problem after wakeup.
Mini10v|N270|160G HD|2G RAM|BCM2046|BCM4322
Default 08-09-2009, 08:21 PM
hmm well many people are reporting(myself included) that their audio does not work after sleep? Well they workaround seems to do just fine as well
AH perhaps the verb helper I had before was your original version! I will try redownloading it and make step 6 optional!
Default 08-09-2009, 08:51 PM
If you got a problem with wake from sleep, would you please try this command "sudo dmesg |grep VerbHelper" and send the result, I may be able to help.
Default 08-09-2009, 09:05 PM
hmm after installing the new driver, I cannot wake from sleep for some reason? here are the results:
Code:
VerbHelper: Audio fix for Dell 10v after the wakeup. (c) Lnxneo, 2009
VerbHelper: VerbHelper: VerbHelper: VerbHelper: VerbHelper: VerbHelper: com_psystar_RealtekR1000: Ethernet address 00:--:--:--:--:--
VerbHelper: VerbHelper: VerbHelper: VerbHelper: display: Not usable
VerbHelper: VerbHelper: VerbHelper: VerbHelper: VerbHelper: VerbHelper: AirPort: Link Down on en1
*I took out my mac address for obvious reasons
Default 08-09-2009, 10:18 PM
Code:
Those are weird log, did you restore the vanilla IOAudioFamily.kext?
Default 08-09-2009, 10:37 PM
ya, haha i thought that appeared kinda odd. Anyways, I believe it is fine as is. I am going to stay with the previous audio kexts and sleepwatcher method for now. I like it because it has no side effects at all and will work for every user no matter what.
But thank you so much for your help! if you can find a fix that works, please feel free to tell me!
« Mac OSX 10.5.7 is here... | Itunes audio plugins not working, any ideas? »
