Default No system preferences for mouse trackpad w/ DellEFI 1.2a5? - 08-08-2009, 04:06 PM
Hi All,
10.5.8 nuked my Type11 install (something went wrong with my video settings and couldn't get back to normal), so I've reinstalled OSX using the current version, DellEFI 1.2a5.
Everything is working wonderfully, but I seem to have lost options for mouse preferences... With the Type11 install, I could go into preferences and adjust mouse options, specifically the single tap trackpad option. Anyone know how I can get this back?
Thanks.
Default 08-08-2009, 04:28 PM
You need to re-run DellEFI and select custom install, and select Restore the 10.5.5 keyboard preference pane. It will add it as a separate entry in the System Preferences.
Functioning Hibernation
« Unable to install OSX on Mini 10v- Please Help! | Mini 9 with OSX will not wake from sleep »
