  (#41) Old
Default 08-12-2009, 02:33 AM
I'm not too sure about this, but my battery life has also dropped fairly significantly since applying 10.5.8. I have a feeling that the machine is stuck in the full power mode that it would be when powered by the adapter. As others have said, this doesn't seem to be a gauge issue, but something deeper. No idea how to fix it though, I'm still learning OS X!
  (#42) Old
tea tea is offline
tea's Avatar
Default 08-12-2009, 07:11 AM
2menders
All you needis:1. DSDT with working HPET
2. AppleSMBIOS.kext (from my post)
3. Working AppleIntelCPUPowerManagement.kext (not Disabled or deleted)
4. Update system by ComboUpdate, not Software update - not all power control components updated by Software Update.
For sleep work you need USB EHCI fix (by VoodooEHCI for example), working Audio (by stock AppleHDA), and comboupdated system.
  (#43) Old
Default 08-12-2009, 09:25 AM
OMG, tea, I love you!!!!
I just put that SMBIOS kext into my install and my battery knows the time now.
  (#44) Old
tea tea is offline
tea's Avatar
Default 08-12-2009, 10:39 AM
One week i told about it in this forum...
  (#45) Old
Default 08-12-2009, 11:13 AM
Originally Posted by tea View Post
2menders
To be honest, I'm not a pro. Should it be possible to explain the steps a little bit more? (For example: 'what it's a working HPET..')
Thanks!
  (#46) Old
tea tea is offline
tea's Avatar
Default 08-12-2009, 11:19 AM
As you can see my English is not perfect and if I start to explain that such DSDT, ACPI and HPET that you will laugh and will understand nothing...
  (#47) Old
Default 08-12-2009, 12:17 PM
tea, thanks for suggestion. I love like to know the root cause ( yes, I understand DSDT ACPI and etc).
It seems that you have old AppleSMBIOS.kext (maybe hacked), I wonder if (SMBIOSResolver + chameleon v1) or (chameleon v2 + smbios.plist) can achieve the same goal. Thanks,
Mini10v|N270|160G HD|2G RAM|BCM2046|BCM4322
  (#48) Old
DMBryant's Avatar
Default 08-12-2009, 12:33 PM
I just installed the AppleSMBIOS.kext file that tea provided on my 10v using KextHelper and it worked!!! I now have a fully working battery meter!
However the 'Energy Saver' panel now just shows a drop down to select settings for 'Battery' or 'Power Adaptor' and the ability to change to optimization for each. I am sure I used to have some slider bars on there with some other options...
Oh well, at least I can see how long the battery has got left
  (#49) Old
tea tea is offline
tea's Avatar
Default 08-12-2009, 12:37 PM
2lnxneo
My first post http://www.mydellmini.com/forum/mac-...html#post90547
This SMBIOS use original dump from real Mac, and inject additional properties.
I'm try inject with Chameleon 2, but no result. I thing we lost board-id property.
  (#50) Old
Default 08-12-2009, 04:27 PM
tea: Thanks for your patience and help. I installed your AppleSMBIOS.kext in /S/L/E and rebooted and all is working again.
« Can't view full images in iPhoto (or Preview) | Is there a way to swap Alt Gr and Delete keys under Mac OS X »
LinkBack to this Thread: http://www.mydellmini.com/forum/general-mac-os-x-discussion/11317-lets-fix-not-charging-issue.html
Posted By For Type Date
menders2's Bookmarks on Delicious Post #0 Refback 08-22-2009 10:31 PM
MyDellMini | Site profile | BoardReader This thread Refback 08-07-2009 04:02 PM
