hrtbrkkid2 hrtbrkkid2 is offline
Default 6 cell battery issue PLEASE HELP - 08-05-2009, 05:30 AM
I am currently running OSX 10.5.6 on my dell mini 9 and I purchased a 6 cell battery from ebay. After installing the battery I noticed that the indicator lights on the bottom left corner of my dell mini keep blinking on and off(white and orange). After restarting the computer I got the following message.
WARNING: The battery cannot be identified.
This system will be unable to charge this battery.
Has anyone encountered this problem. If so what did you do to correct it.
SkyWriter SkyWriter is offline
SkyWriter's Avatar
Default 08-05-2009, 10:32 AM
yes, they don't really work.
see the multitude of threads such as 8 Cells "77Wh" Battery is Here!
Problems with external displays or projectors in OS X? Try MirrorDisplays2!
Got Static?
JCVorndran JCVorndran is offline
Default 08-05-2009, 12:00 PM
I did not have that problem, my 6 cell works on my hackintosh.. knock on wood knock knock
Mini 10v 10.6.1 500 GB Hard Drive 2 GB RAM Camera
jrm jrm is offline
Default 08-06-2009, 06:06 PM
i have that same problem with my 8 cell battery, but it does indeed work. I just cover the blinking lights with tape.
« Very confused.... | very slow 3g via bluetooth »
