gQstatus05 gQstatus05 is offline
Default Need Syslinux help trying to install OSX. - 08-02-2009, 04:02 PM
Ok. I have a 4GB thumbddrive and I'm trying to put syslinux 3.63 on it. Windows won't see my thumbdrive. I went into device manager and deleted USB root hubs, and mass storage. It installs drivers successfully but doesn't appear in my computer.
I went on Ubuntu and downloaded gParted to re-partition the thumbdrive FAT32. Ubuntu sees my drive but windows doesn't and I don't have another windows computer at my house. Is there a way to put Syslinux on the thumbdrive through Ubuntu?
Dell Mini 9 RED | 1.6GHz | 10.5.7 OSx| 32GB SD Card + 32GB SSD | 2GB RAM | 802.11B/G/N | BT |
meklort meklort is offline
meklort's Avatar
Default 08-02-2009, 11:04 PM
You install it essentially the same way you do on windows
1) Download syslinux
2) Run syslinux (instead of ./win32 its in ./linux)
If you need help, either use the manual pages or the output of the program as should tell you how to use it. The command should be very similar to on windows, except instead of using F:\ you use /dev/sda or something similar.
My Blog | NetbookInstaller code repository | NetbookInstaller Website | Want a invite? message me.
« DellEFIBootmaker Problems | Kernel Panic when installing (first boot) »
