jdcnosse jdcnosse is offline
jdcnosse's Avatar
Send a message via AIM to jdcnosse Send a message via MSN to jdcnosse Send a message via Yahoo to jdcnosse
Default 16GB vs 32GB SSD - 07-29-2009, 06:30 PM
So what has been your experience in how much space OS X takes up? I've read OS X 10.5 needs at least 9GB of space to run, but I didn't know if after you've installed other programs (like iLife or iWork/OpenOffice/MSOffice) if you had a decent amount of space left over.
I have about 8GB of music right now in my I would like to place that all on the SSD. It's probably cheaper to get a 16GB SSD and a 8GB SD card, but then I can't really add to my music collection...
CyG CyG is offline
Default 07-29-2009, 06:38 PM
Sounds like you want someone to tell you to buy a 32 Gb HD. 16 gigs is enough to squeeze on what you need but you should do what you want within your budget.
jlozier jlozier is offline
jlozier's Avatar
Default 07-29-2009, 06:45 PM
you could buy a 16gb SSD and a 16GB SD card - I paid £50 for my runcore 16GB and had about 5gb left after installing office and some extra games etc and running xlsimmer.
Over in the UK I canget a 16gb SD card for £18 delivered and a 32gb SSD is £80 - so I'd personally go for what you can afford. if you need to save some money, get the SD and the SSD, if you can afford it, go for the 32gb SSD
jcocci jcocci is offline
Default 07-29-2009, 07:08 PM
Buy the 32gb you'll wish you did if you don't. Every time I've bought a smaller drive to save a little $ I end up kicking myself.
« Parallels Desktop & Dell Mobile Broadband | Installing OSX, does it use a serial key for activation? »
