Default Using External Monitor Only in OSX - 07-27-2009, 06:24 AM
I've searched this forum and Google for help on this. I've found several different things but have yet to find the answer I'm looking for. I already have OSX installed on my Mini 9. I basically want to use it as a cheap Mac Mini. I'd like to be able to close the screen and use only an external monitor. Obviously, when I close my monitor, it shuts off. Is there a way to disable this? Secondly, is there a way to disable the screen on the Mini 9 instead of spanning across 2 screens? Every once and a while something will go over to the Mini 9 screen when I don't want it to. It would be nice to only use the external monitor. Any help is appreciated.
Default 07-27-2009, 07:38 PM
Functioning Hibernation
Default 08-01-2009, 06:49 AM
http://www.mydellmini.com/forum/mac-...hiba-hdtv.html
atm153's Avatar
Send a message via AIM to atm153 Send a message via Skype™ to atm153
Default 08-02-2009, 04:43 AM
Originally Posted by louididdy View Post
pretty sure he means just using the external, not mirroring.
System Specs: "Macbook Mini" Vostro A90, Mac OS X 10.6.3, Stock 16GB SSD, 2GB RAM, 0.3MP Camera, Bluetooth
Software: NetbookInstaller 0.8.4 RC1
Mods: BCM4312 flashed to Airport Extreme, Apple stickers doubled up on the Dell logo, electrical tape over the power light
Default 08-02-2009, 10:14 AM
Originally Posted by underwhelmed View Post
That is just dumb, I think the owner figured that out the hard way that 80% of the mini 9's cooling is through the keyboard, they should've at least taken the screen off and put it somewhere.
I can imagine that gets stupid slow and heats up insanely fast.
I have yet for an external monitor to work, mirroring would be the best, but I can't get anything working.. so again.. until then.......
-Dell Mini 9 - Refurb $269: Obsidian Black, 32GB STEC SSD, 8GB Kingston SDHC (left from previous owner), 2GB 667Mhz RAM, 1.3MP Camera, Bluetooth, Mac OSX 10.5.7
-Dell e1705 - New $1055: ATi X1400 OC/ed 175% faster, XPS 1710 Heatsinks, XPS 1710 Body
e1705 is old, it needs not to be upgraded, but rather be replaced.
Default 08-02-2009, 11:06 AM
I wouldn't do it, and don't recommend it, but it is exactly what the OP was asking to do.
Default 08-17-2009, 04:42 AM
Anyone get external monitor only working? Retarded that this isn't super easy.
____________________________________________
Dell Mini 10v - $215 to the door!
1GB RAM, 120GB HD, 1.6GHZ - OSX 10.5.6
Default 08-17-2009, 05:14 AM
As a side note, if i set it to vga only on bootup using fn-f1 twice, (mini10v) it just hangs and won't boot.
« Issues with OSX after software update. | Good External DVD Drives »
