CKS CKS is offline
Default Stuck after 1st reboot... - 07-24-2009, 08:43 PM
Would love some help.
After using version 8.1 of Type11 off of an external cd/dvd drive and successfully installing OSX v 10.5.6 on my new Mini 9 (it even said, 'Installation Successful'), things have ground to a halt. I put the cd with Type11 back into the external cd drive, restarted the Mini 9 and typed '0' during booting to boot back into the cd drive ... but Type11 won't recognize the OSX install on the partition on my SSD. I've tried it several times to no avail.
Anyone else experienced a similar problem? Did I just brick my Mini? What can I do to make Type11 recognize OSX on my SSD?
Thanks in advance for the help
CyG CyG is offline
Default 07-24-2009, 10:09 PM
Unfortunately, Type11 is no longer a supported method and will not take you up to 10.5.6. If you start over with NetboolBootMaker things should work out better.
Just out of curiosity, how did you decide to use Type11? It would be nice to make sure no one has to go through the same frustration.
« Hangs At Boot Screen w/ diagnosis error. Anyone make sense of this? | Battery Not Charging Anymore?? »
