TchnclFl's Avatar
Send a message via AIM to TchnclFl
Default No external DVD Drive? No Problem! (my makeshift external DVD Drive) - 07-22-2009, 04:03 PM
When I got my mini, it was with the intention of installing OS X on it, and after a few days of trying to riddle out a way to install from a Flash drive, I gave up. I simply could not figure out a way to do it that would work through windows. I then resorted to thinking about external drives, but they were very expensive for a good one. I hatched an idea: I had an external IDE Hard Drive enclosure, and I had an internal IDE DVD drive, so why not put two and two together and try it out? I attached the DVD drive to the enclosure through IDE cables, and powered it through a 4-pin molex connector on the enclosure. After plugging it in (crossing my fingers, and knocking on wood), I turned it on on my main computer. Lo and behold, it worked; it showed up as a DVD drive perfectly, and I could use discs that I placed into it.
I've attached some pictures of the drive and my computer booting into the OS X disc, and yes, that IS a desk made out of DHL boxes that it's sitting on.
Click image for larger version
ID:	1818Click image for larger version
ID:	1819Click image for larger version
Default 07-22-2009, 04:54 PM
anymore pictures of the desk?
Dave
TchnclFl's Avatar
Default 07-22-2009, 06:32 PM
Dave
On my main computer, actually. I'm on vacation this week though, I'll post some more when I get home perhaps.
Default 07-22-2009, 08:14 PM
I considered doing this. I have a IDE to USB convertor, but I don't have an IDE DVD drive, only SATA Thankfully, I think I figured out the flash drive thing.
10v • Atom N280 • 120 GB HD • 1 GB RAM • 6 Cell Battery • Obsidian Black
ish05's Avatar
Default 07-31-2009, 08:55 AM
Great idea. I have an external HDD enclosure that would possibly work to hook up an internal IDE DVD-ROM drive to install a slimmed downed version of XP. Good looking out man.
Dell Mini Inspiron 910 32GB RunCore SSD, 2GB RAM, Windows 7 Ultimate
Dell Inspiron 1720 2x 1TB HDD, 4GB RAM, Windows 7 Ultimate
https://www.facebook.com/pinto.ismael
http://gplus.to/ismaelpinto
Default 02-11-2010, 07:36 PM
you still used netbook bootmaker correct and does anyone know any windows alternatives or a different way to do it without a mac?
« Gray Screen - You need to restart your computer. Hold down | Mobile broadband option with OSX »
