Paradoxgrowth Paradoxgrowth is offline
Default 07-24-2009, 04:05 PM
Oh i see, your priority is to get it to work not a permanent fit (if it does cool if it doesn't you could stilll write the much need driver). I have never seen a 9 but the 10v has one micro cable with all the pins (one connections from the touchpad to the motherboard). I would be unable to follow connects. It would make it impossible to solder those bad boys too. That sucks that your touchpad is glued!! GOD DELL!! man at least my screws on....even though i had to bend a lot of medal to get it to fit.
oh I was just saying it would be cool to see the eee track pad in your 9, if you can get it to fit.
« Bluetooth and trackpad issues + Mic In question | Mini 10v Realtek ACL272 driver »
