tange1 tange1 is offline
Default Super slow mac (% System using 51% or more) - 07-20-2009, 11:51 PM
My mini 9 is having a new and odd issue. It was super slow today so I thought it wasnt booting to the desktop. I booted to safe mode, reinstalled everything (1.2a) and rebooted. I was able to get to the desktop but its super slow to get there. When I was finally in I found the desktop to feel very slugish. I opened activity monitor and found that % system is using over 50%. I can't tell exactly what this means.
I made no changes to start this that I know of. I hadn't rebooted in a long time before this. One new change is the machine fell off the couch this afternoon down to carpet. I used it after that with no issues. I put it to sleep and when I went to wake it I wasnt able. That happens to me occasionally - ever since its been super slow. Help?
Edit: USB bios legacy support is disabled, so is usb wake support.
edit: Resolved by reinstalling efi 1.1 rather than 1.2a5
soul soul is offline
soul's Avatar
Default 07-21-2009, 12:57 AM
Odd, mines running fine... no y2k
Mini 10V | 1.6GHz | 2GB | 16GB SSD | GMA 950 | OSX | ~$180ish | Wireless-N | 6-Cell |
M1340 | 2.4GHz x2 | 4GB | 320GB 7.2K-RPM | Nvidia SLi 9400M + 9200GS | 7-RTM | $500.00 | WEI: 5.3 |
ljsworld ljsworld is offline
ljsworld's Avatar
Send a message via Skype™ to ljsworld
Default 07-21-2009, 01:51 AM
With other machines, your problem usually ends up being a drive issue. Have you considered verifing that the SSD is seated properly. For that matter I would also check the ram.
Mini-9> A04 Bios | 32 gb SSD | 2 gb RAM | 16 gb Kingston SDHC | 1.3MP Camera | BT |
| USB Legacy Mode: Off | DellEFI 1.1 | Track Pad_17 | OSX 10.5.7 |
| Sierra Wireless Compass 597 EVDO | EyeTV Hybrid 2007 |
Default 07-21-2009, 07:33 PM
I'm not sure why it fixed it but I booted to safe mode and first tried installing dell efi 1.2a. No luck. I later booted into safe mode again and reinstalled the efi 1.1 files and rebooted. I found this fixed my issues.
CyG CyG is offline
Default 07-21-2009, 08:23 PM
Sometimes rebooting and reinstalling can accidentally solve a problem with overheating by allowing the machine to cool down. Everything will most likely stay healthy but it's something to keep in mind.
« SDHC Desktop Freeze - RESOLVED | Many, many thanks to you all... »
