darkhunter139 darkhunter139 is offline
Default 09-25-2009, 11:22 PM
Originally Posted by MikePA View Post
Could you explain this? I hadn't read this thread and enabled mirroring and whenever I hook up the external monitor, the display is screwed up. To fix it, all I do is disconnect the external monitor and hit Esc on the Mini. What do I do to fix this?
Running 10.6.1 using NetbookInstaller.
You have to turn off mirroring using terminal, there are a few differnt commands to do this. I forget the exact one I used though.
Mini 9 | OS X 10.5.7 | 2GB RAM | 32 gig supertalent SSD
vickoxy vickoxy is offline
vickoxy's Avatar
Default 01-28-2010, 08:39 PM
Can someone tell me at the end-is display mirroring possible on dell mini 10v at the end (even with mirror display app) or not?
browndogfred0215 browndogfred0215 is offline
browndogfred0215's Avatar
Default 02-04-2010, 08:53 PM
I don't think there is a way to use mirroring.....
« 10.5.8 vs. 10.6+ | How To Change Apple Boot Screen. »
