Krause's Avatar
Default SSD Tweaks on Mac? - 07-08-2009, 12:38 PM
Would just like to confirm if any of you guys out there tried this out... got this from another forum...
Okay, so just to prove I am not just a grumpy old naysayer, here are some things you could do to actually improve performance under OS X.
1) Disable Adaptive Hot File Clustering
This is a feature of the OS that tracks how often files are used and automatically moves them closer to the outer rim of the drive (which is faster on conventional disks). On an SSD it is just a useless block move.
2) Disable automatic defrag
This actually might not be a win, because the system only performs auto defrag in very limited cases (files less than >20 megs with more than 8 extents), and while defragging the file itself will not be a performance win, consolidating its metadata into the file record (so you don't have to walk through the extents btree) might in fact be a win even on an SSD because it significantly reduces the amount of reads you have to do figure out where the file is.
The unfortunate thing is that there is no simple way to do either of these. You could build a custom kernel (it is a ~1-2 line change to short circuit them out). I suspect that neither is going to be a particularly large win though, so you are better off just running a stock (supported) kernel.
Default 07-08-2009, 08:18 PM
How 'bout journaling? Is that bad for SSDs? I've seen a couple of articles that claim it's better to run on a non-journaling FS when on SSDs.
Default 07-08-2009, 08:49 PM
The reason some people recommend against journaling is that journaling causes more writes, and writes are what wears out flash memory. Personally, I don't think it's a problem. EVERYTHING wears out faster if you actually use it, conventional hard drives included.
Krause's Avatar
Default 07-09-2009, 01:47 AM
So does this mean disabling journaling would extend the lifepsan of an SSD drive?
Eligos's Avatar
Default 07-09-2009, 11:51 AM
Either way, your SSD should last ~5 years with normal daily usage. By that time your mini will be no longer or you will pony-up for a new faster SSD.
Dell Mini 9 : OS X 10.6.2 : BIOS A05
32GB STEC SSD : 2GB RAM
NBI Version : Latest
SpeedStep : [Enabled]
USB Legacy support : [Disabled]
Krause's Avatar
Default 07-19-2010, 12:50 AM
is it possible to create symlinks from the items in /private/var/folders/ (or even the /tmp/ folder) to a ramdisk to save on writes?
Previously:
Mini 9  Obsidian Black  BIOS: A05  16GB SSD  2GB RAM  Webcam: 1.3 MP  BT: On  Legacy USB: Off  Snow Leopard 10.6.2  NBI/NBM 0.83  iWork '09  iPhoto '09  iMovie '09  Photoshop CS4  Soundbooth CS4
Mini 9 Obsidian Black BIOS: A05 16GB SSD 2GB RAM Webcam: 1.3 MP BT: On Legacy USB: Off Snow Leopard 10.5.8 NBI/NBM 0.83MSO 2K8 Aperture 3.03
Default 07-19-2010, 10:08 AM
I found this*, a plist to go into /Library/LaunchDaemons/ that claims to turn access time recording off. Haven't tried it yet.
* Google translation
Krause's Avatar
Default 07-19-2010, 01:18 PM
also have that one... has anyone tried to modify it to mount mac's counterpart of tmpfs to /tmp/ or /private/var/tmp/ ?
Previously:
Default 07-19-2010, 05:28 PM
Nope. Gave up as I've not even got this one to work -- a script to maintain /var/log/* in tmpfs and write it to disk on shutdown.
Noobnesse oblige.
ssd, tweak
« For anyone who added the Novatel internal 3G card | Mini Mac back up with Super Duper »
