(#4)
(#5)
| Senior Member Posts: 354 Join Date: Mar 2009 | as far as i remember after installing 10.5.6/1.07/a04 i had external monitor support right out of the box - two such monitors supported 1280x1024, and 1600x1200 @70hz. all my problems however, were with a projector with 1024x768@60hz. for this i tried the mirroring fixes. none of which i could navigate successfully until i found the mirrordisplays2 application (tales of which are documented in many threads found via the link in my sig). after which i have been able to use the projector WITHOUT resorting to the initial execution flailing of the application. moreover i did not lose external monitor support either. since then i have updated to 10.5.7/1.2a5 without issues. one thing to note is that i don't have mirrored displays - just extended monitor that i use with power point. i agree, something is missing. and until the recipe is found getting this functioning will continue to be a dark art. Problems with external displays or projectors in OS X? Try MirrorDisplays2! http://www.mydellmini.com/forum/mac-...html#post73180 Got Static? http://www.mydellmini.com/forum/gene...io-static.html |
(#6)
(#7)
| Senior Member Posts: 354 Join Date: Mar 2009 | Problems with external displays or projectors in OS X? Try MirrorDisplays2! http://www.mydellmini.com/forum/mac-...html#post73180 Got Static? http://www.mydellmini.com/forum/gene...io-static.html |
(#8)
(#9)
| Member Posts: 59 Join Date: Apr 2009 | It doesn't work for me, and another thread from the past it only worked for a few random people but for majority no one can seem to get any of it to work. -Dell e1705 - New $1055: ATi X1400 OC/ed 175% faster, XPS 1710 Heatsinks, XPS 1710 Body e1705 is old, it needs not to be upgraded, but rather be replaced. |
« I need some clarification with DellEFI please
reassigning delete key? +Norwegian keyboard layout »
