inac inac is offline
Default Removing Flash Drive from Mini 9? - 06-24-2009, 07:57 AM
Newb question - Do you have to specifically find a "safely remove hardware" option to remove a USB/Flash drive from the Mini 9? If so, where do you find this option on Ubuntu 8 or 9?
Default 06-24-2009, 01:52 PM
In general, no - Windows typically treats USB drives as safe for removal, though it never hurts to to do the "safely remove". I don't know what Ubuntu does - you may want to ask in the Ubuntu section of the forum as this is not hardware-specific.
Default 06-24-2009, 02:14 PM
In regular Ubuntu, right-click on the desktop icon for the drive and choose "Unmount Volume".
If you're using the netbook remix version, I think you can do something similar.
« Hey! | How long is the McAfee subscription on a Mini 9 »
