curlee357 curlee357 is offline
Default TOO HOT TO QUIT!!! - 05-03-2009, 12:50 AM
HELLO everyone, hope all being well,
OK JUST TO GET YOUR OPINION AND PERHAPS YOUR HELP
I purchased a dell mini 9 and i must say its definitely a cool little joe but there is one thing i must say i,m concerned about and that is OVERHEATING, Some times i have to seize a session for a half hour and turn it side ways up just so it can cool off. Well to my dell family I would like to know 2 things
1.what is your technique (if any) do you use to keep your mini-u under the radar (room temperature)
2. Can my mini-me overheat? ops:
Default Re: TOO HOT TO QUIT!!! - 05-03-2009, 01:23 AM
If you're worried about overheating, I suggest you check the CPU's temperature. And from your other posts, it seems that your Mini 9 is running the Ubuntu operating system.
In Ubuntu, the easiest way to check the CPU's temperature is to open a terminal (under Main Menu > Accessories), then type the following and hit enter:
Code:
cat /proc/acpi/thermal_zone/TZ01/temperature
"cat" is a program to crudely display the contents of a file, and "/proc/acpi/thermal_zone/TZ01/temperature" is the name of a fake file that the OS stores the current temperature in.
Anyways, the output should look like this: "temperature: 52 C".
As for the reading, 60 degrees Celsius or less is perfectly normal. 70 degrees would be hot, but not unheard of. 80 degrees would be worrisome.
Clintre Clintre is offline
Clintre's Avatar
Default Re: TOO HOT TO QUIT!!! - 05-03-2009, 02:00 AM
Actually on the Intel notebook and netbook processors they can actually run quite a bit hotter than the desktop series without damaging the processors. Not saying it is good to push the limits, but even 80 degrees Celsius will not damage the procs. Although I would not push it myself. I have not seen mine go above 70 degrees even in extreme conditions.
XPS 13 Ultrabook
Default Re: TOO HOT TO QUIT!!! - 05-03-2009, 03:36 PM
yep i,m running Ubuntu, OK i went thru accessories>terminal, when it opens is it suppose to be blank page and if not what do i do, do i open a new profile? thanx
Default Re: TOO HOT TO QUIT!!! - 05-03-2009, 03:58 PM
When you start the terminal program, you get a prompt like the following, right?
Code:
curlee357@dellmini9:~$
Enter the "cat" command that I mentioned above at this prompt.
« Dell Billing | Apple planning cheap MacBooks and iMacs? »
