marmaduke marmaduke is offline
Default Info on Outlet Store - 04-22-2009, 03:01 PM
Does anyone know if the Outlet Store will take a Dell Preferred Account? Since they won't take it for business laptops.
Is it safer getting a previously new mini 9 rather then a refurbished or scratch & dent?
Ubuntu mini 9's are hard to find as previously new. How much room is leftover on a 8Gig SSD if Windows XP is installed on it?
My son is constanly taking mine so I thought I'd get him his own.
Retired Mini user
WolfKeeper's Avatar
Default Re: Info on Outlet Store - 04-22-2009, 03:04 PM
Yes, they take the DPA, and refurbs are usually fine. I got one for my wife a few weeks ago and you can't tell the difference between it and a new unit except for the big green refurbished sticker.
Getting an iPad
saltatory saltatory is offline
Default Re: Info on Outlet Store - 04-22-2009, 03:23 PM
My refurb was at my door in less than a week and there have been no problems with it. Skimming through the forum posts, mine seems to be a typical case.
If I recall correctly, my vanilla XP Pro install took up roughly 4-5gigs. You can check out a program called nlite which allows you to strip out unneeded features before you install XP. There's also cheap storage space available in SDHC and USB flash drives.
bunjin bunjin is offline
bunjin's Avatar
Default Re: Info on Outlet Store - 04-23-2009, 12:30 AM
Of the 3 black mini9s' I purchased as refurburished from the Outlet, 2 were mint and the third had a couple very minor scratches. A little Novus #1 plastic polish with soft cotton pad and even my very picky daughter didn't notice.
A bonus is I placed the order (second and third units) on 4-10-09 and recieved on 4-16-09.
I keep an eye out looking for another one. I love the Outlet with coupon in hand.
Pay less and recieve faster. I like.
Oh, BTW....the big green sticker is on the bottom, thus no distraction!
Emilio84 Emilio84 is offline
Default Re: Info on Outlet Store - 04-24-2009, 03:14 PM
Which is easily removed.
Just saying..
And for the record I placed my order on a weds night and recieved my refurbed mini 9 that following saturday. The only mark I could find is a pin size mark near the keyboard that is pretty much invisible unless you know where it is. I am very satisfied with my purchase and the service from dell so far.
« Researchers dissect world's first Mac botnet | Does anybody else browse mobile web sites on their Mini? »
