fatogre fatogre is offline
Default Mini 9 Issue - Random URL text being pasted while typing - 04-10-2009, 05:52 AM
I have my Mini 9 running Ubuntu.
The weird thing is, in the middle of typing, I'll get a URL that I previously visited pasted into the text that I'm typing in emails (in browser) or even more frequently in Pidgin.
I doubt I'm causing it by accidently hitting the trackpad or keyboard. I REALLY try to watch how I type, but it happens again and again.
I read some other users who are experiencing the same issues (with no solution), so I'm hoping that we can all put our heads together and figure this out.
If I don't get this resolved soon, I'm thinking about returning it for another one.
HELP! HELP! HELP!
bluetooth bluetooth is offline
Default Re: Mini 9 Issue - Random URL text being pasted while typing - 04-10-2009, 06:13 AM
Use syndaemon to suppress tapping when typing:
System -> Prefs -> Sessions
Startup Progs tab
Add
syndaemon -i 4 -d -t -K
Then Alt+Fn+S:
Default Re: Mini 9 Issue - Random URL text being pasted while typing - 04-10-2009, 07:11 AM
Startup Progs tab
Add
Then Alt+Fn+S:
So what does this exactly do?
Do i need to run these commands everytime I boot?
Default Re: Mini 9 Issue - Random URL text being pasted while typing - 04-10-2009, 02:57 PM
Startup Progs tab
Add
Then Alt+Fn+S:
syndaemon suppresses accidentally tapping on the touchpad whle you're typing.
If you add it to system/prefs/sessions, then you won't need to type this every time you boot.
Default Re: Mini 9 Issue - Random URL text being pasted while typing - 04-10-2009, 04:41 PM
Thanks for the explanation. I will try this solution and see if this works.
Does anyone else have the problem that I've experienced and the solution above worked?
Any feedback is appreciated!!!
Default Re: Mini 9 Issue - Random URL text being pasted while typing - 04-11-2009, 06:35 AM
Startup Progs tab
Add
Then Alt+Fn+S:
This solution doesn't work. It's NOT me accidentally touching the touchpad. Someone suggested that it might be a stuck CTRL button, but I'm not sure, since we hardly touch/use that button.
Any other ideas? Should I just call Dell and deal with technical support?
yam yam is offline
Default Re: Mini 9 Issue - Random URL text being pasted while typing - 04-12-2009, 12:04 PM
I've noticed this issue too. While typing messages it randomly pastes the URL. I am also using mini 9 with the dell ubunutu
any have a solution ? I ran all the updates
Default Re: Mini 9 Issue - Random URL text being pasted while typing - 04-13-2009, 01:35 AM
I've had this problem occasionally, too. It seems like the touchpad is generating a middle-click upon accidental contact and that causes the paste. I'm not sure how, 'cause I can't get the same thing to happen intentionally.
Default Re: Mini 9 Issue - Random URL text being pasted while typing - 04-15-2009, 05:34 AM
I tried this solution, and THIS WORKED FOR ME (on day 4)!
http://ubuntuforums.org/showthread.php?t=1119474
I copy/pasted the solution below. PLEASE CONFIRM IF THIS WORKED FOR OTHERS WITH THE SAME ISSUE.
Thanks!
Re: Random Text Pastes when typing or clicking
I had a similar problem on a Sony Laptop with Synaptics Touchpad. I don't remember how I got there, but I added the following in my /etc/X11/xorg.conf
Code:
Section "InputDevice"
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizScrollDelta" "0"
Option "RightEdge" "950"
Option "MaxTapTime" "225"
Option "MaxTapMove" "160"
Option "MaxDoubleTapTime" "225"
Option "SingleTapTimeout" "180"
Option "MinSpeed" "0.40"
Option "MaxSpeed" "0.90"
Option "AccelFactor" "0.0060"
Option "RTCornerButton" "0"
Option "RBCornerButton" "0"
Option "SHMConfig" "on"
EndSection
What is important is the highlighted part - it turns off the corner button functions (right-click and paste). You may have to pick the correct Driver and the Device option, as applies to your machine.
« Three OSs. One External HD/File System | Article--Pimp My Netbook (With a Mini 9) »
