mattiemo mattiemo is offline
Default Need help. tried bios upgrade now blank screen. - 03-25-2009, 10:40 PM
i went to upgrade the bios in my mini9 because i need the f11 key. when i went to install the new bios it froze up on me. ( i couldn't even shut off holding the power button) so i pulled the batt. no all i get is a blank screen. the power light comes on and i can turn it off holding the power button. what can i do to fix it?
thanks in advance
somms somms is offline
somms's Avatar
Default Re: Need help. tried bios upgrade now blank screen. - 03-25-2009, 11:22 PM
thanks in advance
Imagine you bricked your Mini attempting to flash under Windows? It may be able to recover but will require an external USB floppy: bios-upgrade-utility-split-from-bios-upgrade-failure-topic--t1063.html-st=0&sk=t&sd=a#p7011
Default Re: Need help. tried bios upgrade now blank screen. - 03-25-2009, 11:26 PM
would it work with an sd card or only with the usb drive?
somms's Avatar
Default Re: Need help. tried bios upgrade now blank screen. - 03-25-2009, 11:31 PM
AFAIK, BIOS flash recovery only works w/old-school 3.5" floppy drive...
Default Re: Need help. tried bios upgrade now blank screen. - 03-25-2009, 11:51 PM
in that link you gave me it stated that i may have to setup the a: drive to boot first. i cant get into the bios screen to change anything so if its not default i am S.O.L.
thanks for the speedy replies
Default Re: Need help. tried bios upgrade now blank screen. - 04-01-2009, 05:58 PM
UPDATE. it was successful thank you so much. (the bios in the link did not work i had to get the .whp file from the dell site but the program worked great)
thanks again
willpower101 willpower101 is offline
Default 10-06-2010, 02:20 AM
dead link
Default 10-06-2010, 03:02 PM
« Down grade BIOS, GX60 | Windows 7 and the Mini »
