stat21 stat21 is offline
Default The hole question !!! - 03-01-2009, 12:54 PM
My partner has a mini and thought that there was a fleck of dust on screen, or bad pixel or something, but as we looked closer and carefully felt screen with cloth it appears to be a 'hole' ...is that possible and is it repairable if so ???
Default Re: The hole question !!! - 03-01-2009, 02:41 PM
In the actual display screen? If so, that's a serious defect and it should be returned to Dell to be replaced.
If the hole is a small one in the plastic bezel above the display, just left of center, that's the webcam active light.
Default Re: The hole question !!! - 03-02-2009, 12:14 AM
thank you your help once again yes in actual screen so will def resolve tomorrow you can feelit and nothing has hit it or anything will let you know outcome .
Default Re: The hole question !!! - 03-02-2009, 08:12 PM
Turned out to be a chip in the screen which i actually took a mile down the road to a Dell partner centre who kindly replaced the screen with no charge. For the record this place has some reasonable Dell PC's and Laptops (outlet) great prices and very helpful friendly staff. NW UK.Very happy with outcome !
« What happened to the Ad link? | Canceled Dell order....went to eBay. »
