ctkelly ctkelly is offline
Default Anandtech tests the Ion platform - 02-04-2009, 07:03 PM
http://www.anandtech.com/video/showdoc.aspx?i=3509
Some key things noted in the article:
1)NVIDIA expects Ion to add between $50 and $100 to the cost of a typical Atom machine.
2)DDR2 and DDR3 memory (up to DDR3-1066)
3)Full HD video decode support
4)The GeForce 9400M that is spec’d for NVIDIA’s Ion platform is the same 9400M used in full sized notebooks. It’s a 16 SP core running at 550MHz with a 1.4GHz shader clock
5)Platform consumed ~20w idle and ~25w load...this is with the atom 330, a dual core 1.6Ghz
Will be interesting how the final product comes out and who moves away from the intel chipset platform to the new nVidia setup.
psyopper psyopper is offline
Default Re: Anandtech tests the Ion platform - 02-04-2009, 07:29 PM
What I think will be interesting is to see how a manufacturer can get a netbook sized battery to provide this much power for more than about 45 minutes.
http://shop.psyopper.com
Default Re: Anandtech tests the Ion platform - 02-04-2009, 07:50 PM
Compared to the atom 230 in the asus EEE box the ion platform only drew 6 more additional watts of power. The 945G chipset is a piss poor performer in many regards, including power draw.
6 more watts for an additional core and a far superior chipset isn't bad at all. Have to wait and see what the manufacturers come up with in the end.
Edit: 1.5W difference between the 230 and 270. 230 has EMT64 and no EIST, 270 has EIST. 330 is basically a dual core version of the 230 with Hyper threading, EMT64, but no EIST.
teeth_03 teeth_03 is offline
Default Re: Anandtech tests the Ion platform - 02-04-2009, 11:55 PM
I doubt they would put the 330 in netbooks, since the 230/330 are the desktop counterparts.
370 perhaps? (thats what the number scheme would generate a dual core atom for netbooks)
*Sold My Mini 9*
« Camera Question | Dell recomendation »
