Cayman Cayman is offline
Default Camera Question - 02-04-2009, 12:55 AM
Can you add the Web Cam on later by purchasing the parts from Dell or somewhere?
Thanks for the help.
Fallstar Fallstar is offline
Fallstar's Avatar
Default Re: Camera Question - 02-04-2009, 02:08 AM
Yes, you can order the parts for the webcam and install it to your Mini at a later time.
I found this post on the forum, regarding the part numbers of the required components, as well as a link to the instructions for the install. LINK
Default Re: Camera Question - 02-04-2009, 02:39 AM
Great!!! Thanks for the info!!
How about the Bluetooth? Can that be done later too?
Fallstar's Avatar
Default Re: Camera Question - 02-04-2009, 05:16 AM
Yes, you can also install bluetooth later.
J613H Card,Wireless,Internal Bluetooth,QH/YM
Check this thread out.
Default Re: Camera Question - 02-04-2009, 08:32 PM
Thanks a million Fallstar!!
Fallstar's Avatar
Default Re: Camera Question - 02-04-2009, 11:42 PM
YW!
« HELP WITH MINI DECISIONS, 9 or 12, GOOD DEAL? HELP ASAP | Anandtech tests the Ion platform »
